kyalami
Flight distance : 44914321 ft
Sweden
Flycaster Posted at 3-16 11:21
I cannot confirm this (as of yet, but will look at this on my Mav Pro Gen I in the next couple of days),
but it sounds right.
When you power up the AC, and when it has finished booting, and you hear the nice lady say "the homepoint has been recorded, please check it on the map"
Hi again,
Just back from a test flight today.
I can see the IMU being green and OK when the drone is started and connected to the remote controller. However, as soon as I start the motors is says MOVING and no green bar any more, just nothing. I take off and hear the voice that the home point is recorded and than look at the IMU again and it says MOVING. The same thing any time while flying. This to me looks like as soon as you start the props or get home point set or flying, you can not see the IMU values any more and there is the text MOVING. I do not know if this is right but think so. Perhaps some one can confirm this. Thanks.
Edit: Just noticed that while flying there is a small blue dott next to the Accelerometer ACC0 end at the bottom of that page it says In Use. there is also a number for that which displays 0.019. There is nothing displayed for the ACC1, more than Moving and the number 0.000.
For the gyrocope GY00 is says 0.007 and for GYR01 it says 0.007 and MOVING for both gyros.
There is no green bar for anny of the IMU levels.
Perhaps these values are represented with these numbers instead of the green bars?
Edit. I can now confirm that the accelerometer values for ACCO and ACC1 as well as Gyroscope values for GYR00 and GYR01 as above are the same green bars I see before starting the props as when I am flying.
