jweaver
Flight distance : 47664 ft
MySky Posted at 3-17 11:07
Are you aware, that you wrote in the Air 2 section ?
And nope to your question. The question is, does it really make sence that you see more than you will get in the final picture ?
You can take the picture in 16:9 and crop it after.
Oops.. that was a mistake.. I will delete this and start again. There is something odd about this forum as it keeps doing this.
I don't know if its the same on the Air2, but on the Mini2, you can't crop 16:9 unless you loose a load of detail.. The whole point of this is that the sensor is 4:3 and when you take photos in 4:3 the resolution is 4000x3000.
But if you set it to 16:9, then the 4:3 image is cropped to 4000x2250.. So if you take a 16:9 and crop it to 4:3, you will end up with somethjing more like 3000x2250..
So you are better off taking photos in 4:3 getting the FULL resolution 4000x3000 and then crop as needed.
