JJB*
Flight distance : 12225059 ft
pauly whitehead Posted at 3-21 12:44
When I got my Dji Mini 2 and did some searching in the forum, JJB was always helping others solve problems. I never knew I'd be one of those same members. JJP I can't appreciate you enough.
@JJP*
Hi pauly,
Visual system has lots of sensors on a MP2, In sport mode the OA is disabled but not the bottom sensor for determine height above surface belows the drone.
Disabling VPS will not, afaik, disable the bottem height sensor.
Easy to check, in Sport mode or disabled VPS hover at 0,5 - 0,6 meter and see if your drone is landing automatically after short 100% down stick. (during this landing you can have stick all neutral, laning will continue)
When you see in PH "forcelanding" : this is the automated landing after short 100% stick down.
Be carefull low flying over water....if flying at 0.5 meter [ yes forward speed flying! in will forceland as well ] and you want to lower your craft with 100% stick down it will enter this type of landing, only way to cancel = UP stick quickly!
About the light:
cheers
JJB
