edubrancalion
Kenya
DJI Gamora Posted at 3-21 07:25
Hi, edubrancalion. Thanks for reaching out and posting your concern. We're truly sorry for the unfortunate experience. If you're using a Charging Hub and that the indicator turns to solid red, please check whether the battery is properly seated/inserted into the charging hub's slot. You can try to replug the battery or put it on a different charging slot to see if the problem continues. Please also test it without using the Charging Hub to verify if that would help. If the battery charges properly, please wait for it to fully charge and then refresh the firmware of the aircraft using the DJI Assistant 2.
https://www.youtube.com/watch?v=XPmWvxeSp7E
Thanks for the answer, but I always charge the batteries correctly in the HUB. I am in a region of Kenya where the internet is very weak, I am not able to make the updates,I wil, try today , soon but you think that by doing the updates the drone will stop sucking the battery energy. One battery is probably dead because it doesn't turn on any lights, the other two will only be used after updating and testing.
I update the firewell and i made a test today. When i fly with high speed the baterries drop to zero, show 0 in the app. I reaaly dont know what to do.
