Hi all fans,
I have question about compatibility between DJI FPV (called V2) goggles and "old" version. Is possible to use new (V2) goggles with "old" DJI FPV Air Unit or not? I think, that old goggles are not useful for new DJI FPV drone (2.4/5.8GHz). But is this possile reverselly? Use new V2 with old Air unit? Try this anybody?
Yes you can swap it over to FPV system in the 'About' menu of the V2 goggles.
There is a software bug though! It will not remember the air units it is bound to if you switch it back to 'FPV Mode' and you also have to re-bind it to the FPV drone. Getting fixed in a firmware update apparently.
Thank you for information, it is usefull information about bounding and un-bounding.
