I tried to grade some DJI footage that I got from @Depp (Thank you)
It is shot in natural profile with 50 FPS.
My first impressions is that it is very good from the start,
Colors are there, sharpness needs a little bit improvement (not much, when it's a fast sequence it's a little bit shaky but if I understand it correct the stabilaizer is not working? I might be wrong here.
The WB is really close as it is.
I just needed to some small small changes to color correct it.
here is the result
So in general I would say that it will be good results from this Drone
Depp Posted at 3-23 08:26
Thanks for posting it. I think I had the stabilizer activated. Will be my missing skills. Looking forward to the split screen.
Hi S
No worries, I just read some where that the stabilizer don't work in sports mode.
But i'm not sure so it's not you that have made any misstakes.
I can be totally wrong here about the stabilizer if it's working or not in which modes.
