DJI Tony
deve87 Posted at 8-7 23:55
My DJI FPV drone and goggle won't record at all. Tried several SD card. Currently using SanDisk Extreme 128GB V30 UHS-I 3 A2 and still not working!! The goggles do not complaining about slow SD card or anything. Goggles show me a record time of 1h54m.. Activated "Record on takeoff" as HardDrone did, but still nothing..
Pressing the recordbutton on remote control once, makes the control beeb. Holding it down beeps twice.
Hi there. I am sorry for the difficulties you are experiencing. First, we recommend that you check the current firmware versions of the aircraft and goggles making sure the firmware versions are the lastest.
If the problem persists, you can upload goggles log and flight control data to us via dropbox/google drive, and send this link to us. And Please record a video of the interface of the goggles when the issue happens.
The way for exporting Goggles Log:
Open DJI Assistant 2, and connect to the goggles within 20 seconds. Then select [Log Export] and click Export to local;
The final exported data is a file in DAT format.
Flight control data can be exported to local via DJI Assistant 2 App
We will do further analysis based on these and solve the problem for you. Thanks for your support. |
