Can this gimbal be set up to be attached to the bottom of a drone?
In the initial promo material there was a shot from a drone in the video but I cant figure out if it was using this gimbal or not on a heavy lift drone.
I'm currently rebuilding my s1000 to carry the RS2
i got the inspiration from this video:
He is using the Ronin-S, but its also possible with the RS2.
You will need 3 additional things to get this work.
The first thing is the Tilta RS2 mount
then you need the Ronin-Focuswheel to get the Gimbal controllable with a classic RC. If you have enough money you also can controll it via Dji force pro.
you also need to get a videotransmission on the Gimbal to have a live view, the Raveneye will not work due the limitation of the range!
I use a classic 5.8ghz FPV transmitter connected via a usb-c cable to power it.
The last thing you will need to do is extend the landing legs on the s900-1000.
I too am looking into doing this but with a rs3 pro instead. I have the DJI transmission kit with 4d handles for focus and gimbal control. just looking for more info on possible weight issues.
