Landey
For comparing cameras it would be better to use RAW pictures taken of the same object under the same (or at least very similar) lighting conditions.
That provides you the sensor output, not post-processed material as with any video file we can pull out of the drone. As already mentioned, YT does also do some post-processing, thus you can never know if a fault occurs due to sensor issues or YT post-processing.
So I guess collecting different video samples would be just a greater waste of time.
Choose a common subject like a test chart, agree on the distance from the camera and the camera's angle, try to achieve identical lighting conditions, light coming from the same direction, identical light temperature. That won't be easy and still won't get you 100 % comparable footage - but it will get you near.
My experience: The sensor IS noisy, I also found noise in very bright areas of photos I took in bright sunshine, noise everywhere, even in the sky or in clouds.
The dynamic range is also quite low, in addition, photo quality also depends on the subjects you frame and their color composition.
I watched the first linked video on my netbook, no magnification, no "pixel peeping" (which is often used as a kind of swear word, but in fact it's a very important step if you really want to know what your sensor is capable of - and because details all contribute to the overall experience).
To the starter of this thread: As far as I can say, your Mini 2 camera just behaves in a plain normal way. This does not mean it provides great quality, great dynamic range, colour rendition or detail resolution - things the Mini 2 camera just cannot deliver. Your camera just performs like all the other Mini 2 cameras out there.
You'll experience a better "feel of quality" if you record higher-contrast footage with more different colours, less dominated by brownish or greenish hues. Try urban settings or other areas with stronger color/brightness contrasts - you'll immediately feel a higher sense of quality. There will still be noise, but it won't be that prominent as with footage showing elements of similar brightness and colour.
The camera is no high-end camera, it just can't given the price. It's a very subject-dependant camera which can show muscles and weaknesses all according to the footage recorded - and the depth of pixel peeping.
In short: All okay with your camera.
Addition: ND filters won't improve the picture quality, just change (sometimes improve, sometimes worsen) the perception of motion.
