mavic2zoom-ch
Flight distance : 5547667 ft
DJI Stephen Posted at 3-25 02:15
Hello there mavic2zoom-ch. Good day and thank you for reaching out. May we know if the said DJI Drone had a hard landing before? In addition when the said DJI Drone is flying forward against the wind, in order to resist the wind, the aircraft needs to maintain a larger attitude, and the gimbal is relatively easy to reach the upper limit position, which may cause the phenomenon of dropping down. It is recommended to adjust the gimbal downward or slow down the flight speed when flying forward against the wind. When flying forward in Sport Mode, since the speed is faster and the aircraft attitude is larger, in this case, the gimbal may easily drop down, you are recommended to adjust the gimbal downward or control the aircraft to smoothly to avoid a sudden change in speed.
[view_image]
It's almost new and has never had any hard landings or crashes.
I see what you mean about the tilting of the drone and the wind - it's the opposite to what you said, the gimbal pivots upwards but it's possible that was because I flew it backwards. I'll do some testing to see if it's a wind problem or a drone issue.
I understand this isn't something common, then. |
