djiuser_gWypjWbOEfA3
Hello,
I'm trying to run the Payload SDK sample on a Linux machine. When I run the sample, it connects to the Skyport V2 successfully, but it fails to connect to the aircraft (See attached console_output document). I checked a lot of resources on the internet as well as your PSDK documentation, but I cannot find out what can be the problem. Hopefully anyone can help me out with this.
Attached you can find a screenshot of the DJI assistant and a schematic overview of the hardware setup.
Console output:
Get current log index: 26
[2441509.205][module_core]-[Info]-[PsdkCore_Init:76]Payload SDK Version : V2.2.1-beta.0-build.315
[2441509.226][module_core]-[Info]-[PsdkCore_WaitAdapterConnection:234]Connect to Skyport V2 or X-Port success
[2441509.246][module_core]-[Info]-[PsdkCore_PrintAdapterSerialNumber:278]Get serial number of Skyport V2 or X-Port is 39CDH6P0010053
[2441509.246][module_core]-[Info]-[PsdkCore_Init:130]Updating PSDK policy file.
[2441509.276][module_aircraftinfo]-[Info]-[PsdkAircraftInfo_GetDevelopmentKitTypeAsyncCallback:483]PSDK adapter type is Skyport V2.
[2441509.458][module_command]-[Warn]-[PsdkCommand_SendASyncHandle:858]Command async send retry: index = 1, retryTimes = 3, cmdSet = 3, cmdId = 253
[2441509.661][module_command]-[Warn]-[PsdkCommand_SendASyncHandle:858]Command async send retry: index = 1, retryTimes = 2, cmdSet = 3, cmdId = 253
[2441509.863][module_command]-[Warn]-[PsdkCommand_SendASyncHandle:858]Command async send retry: index = 1, retryTimes = 1, cmdSet = 3, cmdId = 253
[2441510.065][module_command]-[Error]-[PsdkCommand_SendASyncHandle:866]Command async send error 1
[2441510.065][module_aircraftinfo]-[Warn]-[PsdkAircraftInfo_GetAircraftTypeAsyncCallback:416]get aircraft type timeout.
[2441510.246][module_core]-[Info]-[PsdkCore_Init:133]PSDK policy file update success.
[2441510.746][module_core]-[Info]-[PsdkCore_Init:146]PSDK is connecting aircraft.
[2441511.246][module_core]-[Info]-[PsdkCore_Init:146]PSDK is connecting aircraft.
[2441511.478][module_command]-[Warn]-[PsdkCommand_SendASyncHandle:858]Command async send retry: index = 0, retryTimes = 3, cmdSet = 3, cmdId = 253
[2441511.680][module_command]-[Warn]-[PsdkCommand_SendASyncHandle:858]Command async send retry: index = 0, retryTimes = 2, cmdSet = 3, cmdId = 253
[2441511.747][module_core]-[Info]-[PsdkCore_Init:146]PSDK is connecting aircraft.
[2441511.882][module_command]-[Warn]-[PsdkCommand_SendASyncHandle:858]Command async send retry: index = 0, retryTimes = 1, cmdSet = 3, cmdId = 253
[2441512.084][module_command]-[Error]-[PsdkCommand_SendASyncHandle:866]Command async send error 0
[2441512.084][module_aircraftinfo]-[Warn]-[PsdkAircraftInfo_GetAircraftTypeAsyncCallback:416]get aircraft type timeout.
[2441512.247][module_core]-[Info]-[PsdkCore_Init:146]PSDK is connecting aircraft.
