DJI Gamora
Hi, rananavin. Thanks for reaching out and posting your concern. We suggest turning on first the DJI OM 4 wait for it to initialize before opening the DJI Mimo to see if that helps. If it doesn't, you can reset the DJI OM 4 Bluetooth. Press the M button, shutter button, and trigger simultaneously to reset the Bluetooth connection. The Bluetooth connection is reset successfully when the system status indicator turns from green to yellow. Another suggestion that you can also do is either remove the DJI OM4's Bluetooth in the list before reconnecting or do a Network Reset( NOTE: This also resets Wi-Fi networks and passwords, cellular settings, and VPN and APN settings that you've used before). |
