Labroides
Flight distance : 9991457 ft
You initiated RTH at 13:02.1 and it appears to have worked normally and brought the Mavic back from 1362 feet away and brought it back to directly above the home point at 13:49.1.
The issue you are concerned about shows up in the autolanding after that.
There appears to be a problem with your controller.
Much of the time the recorded data indicates your right joystick is being pushed a little to the left when it should be centred.
You can see this in the indicated joystick positions here:https://www.phantomhelp.com/logviewer/H5RLEYZ7CHKBDOJYYD8Q/
Look at the period after 13:49.
This is what you noticed affecting your autolanding after RTH, but it was also affecting the rest of your flight much of the time.
You need to recalibrate the controller to fix this issue. |
