I'm not exactly sure what is going on with my camera but it's starting to get a mind of it's own with the video settings. I using it solely for fishing. It's always set to 1080/60 with a 5min loop. The camera is now starting to not remember what settings I have after I press "stop recording." For example, I catch a fish, hit stop recording. I then hit the record button and for no reason at all, it's now set to 1080/MAX. I have no idea why it kicked out of the loop mode. I turn the camera off, then turn it back on. Now the settings are 2.7K (don’t remember the frame rate). Then it literally takes a picture WITHOUT ME TOUCHING A BUTTON! I saw the entire thing happen. Most of today the camera worked as it should but it kicked out of the settings enough where I feel like I have to check the camera every time I hit record to make sure it's set to what it should be. I shouldn’t have to be doing that.
It's impossible for me to document the problems….no rhyme, reason or pattern to any of it. I'm on FW 01.09.00.10(7211) and will also note, that I have two OA camera's, the other camera does not function like this and they are both running the same FW.
