RGB picture flying direction
GabiSK
Slovakia
I bought P4 Multispectral. I made pictures, everything went fine. When I compile the whole parcel in DJI TERRA on RGB picture you can see the flying direction. The ground is flat, but the picture is "wavy" as if there were a difference in level. Did I something wrong? Is there any setting where can I fix that problem?
2021-4-5
iska
Serbia
what was overlap settings?
2021-4-6
GabiSK
Slovakia
iska Posted at 4-6 01:41
I attached two pictures to see all settings
Front overlap ratio 75%
Side overlap ratio  60%
2021-4-6
Malvir
Flight distance : 1265978 ft
Serbia
GabiSK Posted at 4-6 11:20
If you look carefully at the original images I guess that you will see the most likely reason for the resulting stripes. It seems that Sun was shining approximately from the South - therefore southern part of each picture probably shows shaded side of plants, while northern part of each picture shows lit side of plants. Shade difference could be more obvious in the resulting map when side overlap is low... Obviously, with low overlap there other possible artifacts when using simple stitching and simple cameras - which usualy wil not be so obious after normalizatation in vegetation indexes.
2021-4-17
GabiSK
Slovakia
Malvir Posted at 4-17 11:39
I think is not obvious. The vegetation on the picture is just around 5cm and I took the pictures around 12 to have the best result
2021-4-17
Hakai
Flight distance : 21699 ft
Yes this a a common challenge. It looks wavy because of alternating direction of passes. There is not a lot you can do with it now without reflying it in an east-west direction. You could use an index like NDVI and that would probably smooth it out some.
Some tips here for future https://www.tandfonline.com/doi/ ... 797254.2018.1444945
2021-4-20
Malvir
Serbia
GabiSK Posted at 4-17 13:34
It might be that I am not right and that there are other reasons too. Lets say that we have encountered such problem when imaging 10-15cm tall onion leaves  at 14:00 and using some non-DJI software... Have you tested the same images in other software as well? Are you able  to share some image samples?
2021-4-24
