Hey, thanks for the LUTS! I created a video testing them in DaVinci Resolve. I hope I did it correctly and I hope it helps! https://youtu.be/dQuy7gwqhSg
hi, can You help me with one thing? I’m trying to use those LUTs in Lumafusion (iPad) but there comes an error stating those have invalid size (65) while Lumafusion accepts only LUTs size 2-64 (as I understand they are too big?). I’m not familiar with LUTs creating/resizing process. Can You shrink them or something?
thorgz Posted at 4-9 01:27
Greetings! I made especially for you the size 64x64x64. Good luck in the creative and publish links to your work, I will be glad to see.
Nathan Acre Posted at 4-11 12:25
Thank You so much! I’ve just tested it and it works great in Lumafusion/iPad!
I’ve googled few LUTs made for D-cinelike and Yours is the best there is (tested in Davinci/Windows).
Would be very informative if we can have comparisons including a shot by the Pocket in Normal, D-CLike and D-CLike + LUT.
So far I'm pretty pleased by the default results using Normal Color, but am curious. Thanks you.
Thanks for a great LUT and sharing it on here. I have recently purchase a Calibrite ColorChecker passport photo 2 and was intending to do similar. However I was not sure what settings to use in the column starting ‘source gamma’ for the DJI pocket 2 D-cine in the Color Match area of Davinci Resolve. I already have LUTs for my Fuji X-T4 but I would like to create LUTs for my GoPro hero 11 (Flat) and dji mini 3 pro drone. Any help about setting and the steps that you took would be very welcomed.
How can I find out in which color space I created a video? Normal or D-Cinelike. The recordings are older and I can no longer remember the Normal or D-Cinelike setting.
