Huginn Kenningar
Flight distance : 49635259 ft
Bypass only works in normal mode, cine mode uses "brake" and sports doesn't stops you from crashing at all, but sensors will still beep. Bypass also doesn't work on video modes that require much power, like 5.4K, 4K/60, etc
Bypass causes the drone to fly clunkier and in a totally unpredictable way and at any altitude you'll lose agility, as the aircraft will turn slower than in brake mode.
Brake mode is the way to go for safety, I'd only use bypass if I want to make a reeeally close to obstacles video run at full stick (those that seem that you are going to crash, but not). I'm on brake 99.99% of the time, except when sensors start malfunctioning during bluehour (brake the drone for no reason at all), then I just change to sport mode till it gets darker and back to normal/brake again. |
