JJB*
Flight distance : 12401030 ft
Hi Thomas,
It is not abnormal to see minor negative numbers just before landing.
Baro height is set to zero at takeoff, flying from zero height to 120 meter and back again to where you start...you would expect again a zero value but sometimes you see a plus/minus variation of few meters ; wich is normal.
If the local barometric pressure is changing a little during flight, this is also seen in a plus/minus value instead of the expected zero value.
cheers
JJB
