Mark The Droner
Flight distance : 2917 ft
Hello. Your first sentence says you cannot get GPS to work. Have you read the manual? As a rule, the procedure it to walk out to an open field with plenty of sky above. Place the P2 flat on the ground. Turn on your controller first with both S switches up. Then turn on the P2 series AC. Then wait. Watch the lamps. From the lamps, you will know whether your AC has a connection with your controller. When you see 20x quick green flashes, it's telling you the compass is working. When you see 20x quick green flashes a second time, it's telling you the GPS system has found its sixth satellite and the home point is marked. If there is no GPS fix, or if the lamps indicate some strange error, you should check your GPS module connection with the centerboard. You should also check the compass connection with the centerboard. You should also confirm there is no crack in the GPS antenna. Good luck. |
