Huginn Kenningar
Flight distance : 49635259 ft
He uses a battery mod, and may be using an amplified antenna like the Alientech one.
On stock drone and stock controller he did about 7Km (go and back) on a windy day.
With sensors deactivated max distance should be about the same as the Air 2, or a little less, but depends on the angle of attack and the efficiency of the blades. Air 2S cruises 9Km/h faster than the Air 2 so although it drains more battery due to it's weight, travles faster.
Same thing happened when comparing the range of the Air 2 vs the Mavic 2. Despite having less official flightime (the same as Air2S) the Mavic 2 achieved longer ranges than the Air 2 due to it's faster travel speed in normal mode.
Although Air 2 and Mavic 2 perform better on stock at long range (Air 2S is bottlenecked by the battery), a modified Air 2S with double battery and Alientech 2.4Ghz boosted antenna on the controller should be the best long range quadracopter now, due to it's 4 inbuilt antennas.
