Blithe74
Flight distance : 254367 ft
Russia
Henrik Olsen Posted at 7-8 00:43
it would be interesting to see a screen recording from a device that is working without lag - one guy posted a video, saying it's working fine, where the video clearly showed lagging. I guess we all have different perceptions of reality
Hi Henrik!
When a record is enabled, the following occurs:
1) Drone records a video.
2) Drone sends video stream to SC.
3) SС displays the video stream to screen
4) The SC writes the video to the memory card.
Thus:
The video, recorded in the drone, will lag behind the real position of the drone, the image on the screen will lag behind the video, recorded in the drone, the record in the cache will lag behind the displayed on the SC.
In my opinion, it is necessary to compare the real position of the drone and the image on the screen SC (no screen shots, only external camera). It is this indicator of flight safety. Everything else doesn't matter.
It is necessary to simultaneously shoot: drone, sticks and the screen of SC, for compare the reaction of the drone to sticks and how the real position of the drone is displayed on the screen SC.
In addition, delays may be associated with a low write rate of the memory card. Are you using built-in memory or an external card?
If you use an external card, can you replace it with a faster one? |
