Quickshot resolution is not in the camera preference window.
1437 11 2021-4-20
Ontario Drone
I have gone to this forum about this and elsewhere.  I have found many answers and videos on how to change Quickshot resolution from default to 4K.  These instructions have not worked for me.  This seems to be common.
I have launched my Mini 2 and had it hover in front of me.  I then went into Quickshot mode and switched from Dronie to Circle following one person's video to the letter.  At that time I went into the camera preferences.  The menu for resolution was not there.
Has another one of my settings negated me being able to set Quickshots to 4K?  I have only had my drone for six days now….a total newbie. Frustrating!
2021-4-20
yogi053
Flight distance : 7956778 ft
Whilst in flight, don't you select 4k first before selecting Dronie, Circle, Rocket etc?Remember the app has just been changed as well to move the Camera menus about!
2021-4-20
Ontario Drone
Actually, I tried that first then did what I explained following a video as reference.
I will try your suggestion again next time I fly.
Thanks for responding.
2021-4-20
SuperWinnieperruna
Flight distance : 542083 ft
If i am not wrong,Mini2 only films quickshot mode on 1080p  , even if you before it selected 4k or 2'7k ... other users can confirm this if possible
2021-4-20
Ontario Drone
The Quickshots default resolution when factory shipped is 1080p.  One has to manually change the resolution to 4K.  That is what I want to do but I can't get that option in the camera  preferences and I am not alone for some reason with this problem.
2021-4-20
BaliSkies
SuperWinnieperruna Posted at 4-20 09:44
Wrong wrong wrong.
2021-4-20
SuperWinnieperruna
so ... what's the sequence to get 2'7k on quickshots?
2021-4-21
DJI Gamora
Hi, Ontario Drone. Thanks for reaching out and posting your concern. Kindly let us know if you're still experiencing the same issue. If you do, please check the version of the DJI Fly you're currently using. If you could upload a screen recording of the process you're doing to change the resolution of the QuickShots, that'll be helpful. Many thanks and keep us updated.
2021-4-22
ozoffi
Flight distance : 55128 ft
Austria
I haven't tried the new APP version yet, but so far you had to be in quickshot mode AND the drone therefore had to be in the air AND have a good GPS signal. Then you could go to the settings menu / camera and then you could select the resolution for Quickshot. Unfortunately, the frame rate could not be selected, it was always recorded with 30FPS.
My setting 4k30FPS was retained even after the update to the current version.
2021-4-22
Ontario Drone
Hello DJI Gamora
We are having bad weather today.  Tomorrow is better and I will launch then to get you the screen shots.
I will also note the amount of satellites connected for the GPS as well as ozoffi  suggests.
Thanks,
Bill
2021-4-22
Ontario Drone
I got out today to get the asked for screen shots of the preferences.  During this flight I had 21 satellites.  The screen shots are of me bringing up "QuickShots while in flight, then going to QuickShot preferences.  Still no resolution options!
I hope someone can help me.  All I want to do is have QuickShots at 4K.
Thanks,
Bill
2021-4-23
Ontario Drone
FINALLY!!!! I  found an answer in the new thread called “Camera Settings have moved!”
(https://forum.dji.com/forum.php? ... D766%26typeid%3D766).
Camera settings were moved in the latest firmware update to the lower right hand corner of the flying screen. If you look in the first image in the response above you will see the resolution of 1080p for QuickShots.....
The video in this thread explains how to change video resolution, including QuickShots (now at 4K), and very other camera setting.  Very easy to do AND it works.  Thank you Ian in London.
2021-4-24
