DJI Pocket 2 Gimbal Stuck
124 1 4-20 12:53
Michella
Denmark
Hi, i am having a problem with my 3 month old, DJI Pocket 2 where it won't fold down correctly when turning on and off. Also when I tilt it to the right side it won't tilt the same way as the left side (It is just kinda stuck). When I try to turn the Gimbal back and forth in the place where it is stuck, it is kinda tough and not smooth. How can I get it to turn smooth again so it does not get stuck?
It has not been dropped or damaged.
4-20 12:53
DJI Stephen
Super Moderator
Hello there Michella. I am sorry to read and to know that you are having this issue with your DJI Pocket 2 and thank you for reaching out. Are you able to post a short sample video showing the said issue for us to see and assist you further? Thank you.
4-20 20:37
