Wolferl
Flight distance : 23793 ft
Austria
Dye29 Posted at 4-25 20:58
Thanks for reply but wont let me upload a vid for some reason , but if i plug battery in charger the charger led is red and no lights on battery at all but if i press the batter power button twice it flashes 1 green led then goes out hope this helps thanks .
Hi,
May be the battery is deep discharged and so the charger does nto accept it.
You can try to insert the battery into your Spark, then connect a USB cable from the charger's power supply brick to the Spark (or use another USB charger capable of at least 2 amps) and let it sit overnight.
Let us know if that works.
Cheers,
Wolferl |
