DJI Stephen
 Super Moderator
Hello there eminosfer. I am sorry for the trouble this has caused and thank you for reaching out. Can you please try using a different mobile device for us to be able to isolate the said issue? Upon checking the said mobile device ( Samsung M20 ) that your are trying to use on your DJI Mavic Mini and with the DJI Fly application. I am sorry to say that the said mobile device is not recommended for the said drone and with the said application. We would suggest using a recommended mobile device for the DJI Mavic Mini and with the DJI Fly application for compatibility and reliability purposes. There is a possibility that the Samsung M20 will be able to work on the DJI Mavic Mini and with the DJI Fly application. But however, since it's not yet optimized with the said drone and with the said application we cannot guaranteed if it will work all the time and if it will be able to run all the functions of the DJI Fly application while using it on the DJI Mavic Mini. For reference, I will post a link where in you can check the recommended mobile devices for the DJI Mavic Mini ( https://www.dji.com/mavic-mini/downloads ). Thank you. |
