wrebble
Flight distance : 319606 ft
Estonia
Chuck Campfield Posted at 4-29 08:11
“I could edit a jpg image file to look as good as the manipulated dng image” -Labroides
I know the .jpg format and Photoshop have come a long way but can you really edit a .jpg to look as good as an edited .png? Not trolling at all, just wondering if I should be shooting in .jpg + raw considering my limited ability with Photoshop. At the moment based on my Photoshop skills I think the .jpg right off the camera looks more natural than anything I can produce by editing the .dng. Most likely just a result of my limited experience with Photoshop.
I quote Adobe webpage -
"When an image is captured in a digital camera, it is recorded as raw data. If the camera format is set to JPEG, this raw data is processed and compressed before it is saved in the JPEG format.
If the camera format is set to raw, no processing is applied, and therefore the file stores more tonal and color data. With more data stored in the file, there is more processing flexibility than a JPEG can offer. Here's a cooking analogy: a raw file contains the ingredients to make a specific meal that you can prep however you'd like, whereas a JPEG is that meal already cooked, and there is less flexibility in how you can modify it."
Here is a link where you can read a bit more about JPEG vs RAW (pros and cons) and a few examples also - https://photographylife.com/raw-vs-jpeg
You can get beautiful pictures from .jpg files. They just may be overprocessed therefore you might lose details from image and you can not revert it. For example my Mavic Air 2 oversharpens and uses too much noise reduction on JPEG files causing 'washed out' effect on fine details and I can not make it better.
My suggestion is if that if you are happy with .jpg files then continue using it. If you want to get most details out of your image at max resolution (for print, PC wallpaper etc) I suggest using raw file.
Learning how to edit RAW files does not take years. So if you want to get the most of your drone shots you will get there relatively fast.
