Focus like action cam
579 5 2021-4-28
fansc9bfea30
Hello,
I use the pocket 2 as an action cam to film mountain biking.
I have a problem with the autofocus which focuses continuously and we often get blurry images.
Fixed focus also gives me blurry images.
How to have a definitive adjustment with an infinite focus like the osmo action ?
Thanks
2021-4-28
Marty Markoe
Flight distance : 15135 ft
Although my Pocket 2 is primarily used for still photos, the same issue focus exists. If the screen area requiring primary focus is not tapped, the image is often out of focus.
2021-4-28
vtt64.com
Thanks for you reply,
If I understand correctly, I have to switch to fixed focus mode and systematically tap on the screen on an infinite point? at that moment, i would have an action cam mode at the focus mode?
2021-4-28
DJI-ytao
DJI R&D Squad
Flight distance : 1209413 ft
when pro mode is on, you can choose focus mode: AFC and AFS.
choose AFS and tap to infinity. u will get a focus at infinity.
2021-4-28
fansfe82067d
But as it's not an infinity focus lens, if you focus on infinity, objects anywhere close to you will be out of focus.  The Pocket 2 is not an ideal choice for your purpose, I would have thought - a gimbal camera and an action camera are two very different devices.
2021-4-30
vtt64.com
I use the Fimi palm 1 & 2 for my videos, I have no focus problem.
The pocket 2 is much better in image quality but I would really like to be able to configure this focus as an action camera or like the Fimi.
I did a test with the focus in AFS mode and tapping on the screen infinity, it seems to work, I did not notice any blurry object in the foreground.
The problem is that you have to repeat the operation each time you switch it on.
2021-5-1
