Huginn Kenningar
Flight distance : 49635259 ft
b9y Posted at 4-30 13:55
Correct me if I'm wrong but wouldn't altering the wide angle reduce the resolution? So it wouldn't be 5.4k any more?
Also do you know how much they show and in what situations? I haven't got one yet, I want one, but unsure about it. Massive oversight on DJI's part. I don't use sports mode a lot but need it for when I'm doing quick overflies in slowmotion.
Sorry, what I tried to say is that the'll probably modify the gimball movement settings to help the props stay out of frame.
I see how being such a wide angle lens it's harder to set the gimball correctly for all the situations.
You usually see them on the upper left or right corners of the frame when going fast, looking upwards and turning at the same time. But if there's enough wind for the drone to tilt you'll probably see them too.
I'ts not a massive thing, but you can definetely see the tip of the props in some situations, but I expect they'll solve it in the upcoming updates.
