hallmark007
Flight distance : 9827923 ft
ForceBlast Posted at 5-4 06:02
So I think there might be a bigger problem here. As I said, my video did not return even when the drone was 1 meter away from the remote. There's no way it was a signal issue at that point. I even rebooted the remote and killed/restarted the DJI Fly App prior to finally rebooting the drone. Only rebooting the drone restored the video.
I'm not sure where to go from here. I just hope this thing doesn't crash due to lost visual sensors at some point. It hasn't happened again so far, but I haven't done a ton of flying either.
I would say from experience you should do a complete refresh of both FW and SW, particularly FW, many times when updating dji FW you reach 100% but for some reason it doesn’t fully complete and can cause similar issues , so before sending back plug into dji assistant and refresh try it then and see if this helps. Alternative is return and wait for a replacement that will require an update anyway, or just carry on and hope it corrects itself. Ive seen it happen before and usually refreshing last FW does the job. |
