Duane Degn
Flight distance : 622234 ft
rgp1942 Posted at 5-13 13:35
If you have the time and inclination, I would really appreciate a "how to" list...
1. Do this...
2. Then do this...
I have two sets of goggles myself. Both goggles came set up to use with the DJI FPV Drone.
I know my goggles work in audience mode so if I were trying to get other V2 goggles to work in audience mode, I would first try to pair them with DJI FPV Drone and make sure the goggles have up to date firmware to use with the FPV Drone.
Here's a link to the Fly App I'd use.
https://www.dji.com/downloads/products/dji-fpv
The whole process will likely be a pain since each set of goggles will need to be paired with the FPV drone and then the original set will have to paired again in order to restore the original pairing.
When I updated the firmware on my goggles and drone, I connected the shorter USB "On The Go" (OTG) cable to the goggles and then connected the longer USB cable to my tablet. As I mentioned earlier, the Fly App won't install on my phone. I just checked the latest version and it also won't install on my phone which is a few years old.
Set each goggle up as if it is to be used with the FPV drone and then hopefully you can use them in audience mode. The audience mode for the new FPV drone is different than the audience mode for the Air Units. To use audience mode with the Air Units the goggles have to be set in an alternate mode. I haven't used this alternate mode myself so I won't try to explain how to use it.
When the goggles are in the mode to use with the FPV drone, the master unit has to set to Broadcast (I don't recall the exact menu, if you can't find it let me know and I'll go into more detail). Once the master goggles are set to broadcast, the other goggles (while in the new DJI FPV drone mode) should be set to spectator mode. Once in spectator mode, a list of possible transmissions will be listed. The appropriate transmission should be selected and then the menu needs to be closed.
I know I've typed out instructions on how to select "Broadcast" and how to select "Spectator" so if you have trouble finding these option in the menu, I'll either find my earlier post of type them out again.
I think the biggest hurdle is to make sure all the goggles have the same firmware and set in the appropriate mode (old FPV vs new FPV (I don't know official mode names. Whatever they are they are likely confusing.)). |
