Ian in London
Flight distance : 8330187 ft
hallmark007 Posted at 5-13 15:25
But do you not realize that its the controller that sets that and simply changing RC to normal ATO will eliminate this.
Ive been around here long enough to know that if dji set app straight IE normal at take off then the other half of flyers will tell you there’s a bug with the RC and if dji go back to stopping take off until you put switch to normal the other half will whine about delays at take off, I know thats 3 half’s ;+)
I didn't mean it to be a rant, and I'm defo not offended by anything you've said as you always make good and valid points. My issue is that there is a mass of info and checks you need to undertake when taking off, and in the heat of the moment, it's actually quite easy to miss things when the screen is saying one thing but the drone is doing another.
I actually cannot remember the last time I tried to take off in Sports mode as of course I usually land in Normal mode, so it's not actually true to say "I've been flying long enough to know you can't take off in Sports mode". It would be truer to say "It's easy to forget you can't take off in Sports Mode if the screen is telling you that you're flying in Sports Mode when you're not". And that is my single beef here. It's' a screen; they could easily do ANYTHING to make it clear that S mode isn't actually selected, but instead they just leave it showing S Mode or C mode. And the number of comments both here and on the video should tell you that despite your experience, many people have been caught out by this, and therefore that proves it's misleading and bad design. (IMHO)
