Once again the Mavic Mini delivers BEYOND expectations! Client was BLOWN AWAY with the quality of the results, and I quote "This (video) will SELL this listing!"
I was dealing with stronger than ideal winds while shooting, but for the most part was able to overcome the biggest issue I've been facing these days with the Mini, which is the gimbal does NOT level properly much of the time. It does seem as though the issue is a bit worse when there is a wind over 6-8 Mph. I've noticed if I do a quick full 360 pan around that seems to level it... but there are obvious limitations with that strategy.
This image is completely unaltered, straight from the Mini, which was NOT in FPV mode. It apears to be about a 4 degree difference in angle between the gimbal and horizon. Starting to think I should send this unit in to DJI Refresh care, I guess with sample images showing the issue, since when you turn on the drone it always starts up and intializes gimbal just fine. I'm interested if anyone else has sent a Mini in to Refresh care for a similar issue and what the results were?
DowntownRDB Posted at 5-10 06:25
Beautiful footage. Awesome property. Glad to see Mini is still performing so well despite the gimbal not leveling proper all the time.
Hey, thanks DowntownRDB!! Yeah, that little MM is really incredible!
