AlansDronePics
Flight distance : 814751 ft
Guernsey
I thought you did well manually circling the silos, it is a two stick process. I practiced around my car to get the hang of it. The faster transition at the corners was the challenge. Regarding the blur as you slide sidways, that move is always best avoided when you are close to the subject. Two things I found that helped was to increase the camera frame speed or slide past slower, as you realise. Where you keep the subject at the centre of the screen as you circle, that was done perfectly. No normal viewer will care about the background in that situation. I like the gentle climb, after takeoff, it was effective. you could have cut out the actual takeoff scene and the overlong over-field flight. I scrubbed past to the silos, because it got boring. Pleasant scenery with good colour and sharpness, added to the video. Regarding the absence of sound, most times that bit is so badly done by the video maker that I mute unless the video is worth watching. Your video wasn't edited, so no sound was a sensible omission. |
