youtube.com/rtrrey
Flight distance : 848038 ft
You can't do anything on your end, the file from fly safely data script is corrupted and you wont be able to start the motor.
If you get a reply from an Admin or Mod they will copy and paste this here:
Hi there, sorry for the issue. Just to verify, did you refresh the firmware via DJI Assistant2 before the "Flysafe database error" occurs? If not, please confirm whether you had manually updated the [aircraft safety database] on the app? At the same time, the below information is needed:
1.Screenshot of the [About] page of the goggles V2, need to see the version number of the aircraft [Flysafe Database];
2.Take Aircraft to connect to the DA2 to export the Controller Aircraft Data,choose "Log Export";
3.The specific time node when "Flysafe database error" appears.
Please upload the logs to Dropbox or Googles Drive and then share the link with me. Thanks. |
