JJB*
Flight distance : 12225059 ft
DJI Stephen Posted at 5-11 20:04
Hello there seamusob. Thank you for reaching out and for these information you have posted. Since this is a 3rd party charger ( solar panels ) to charge your DJI Mini 2 intelligent flight batteries. I hope that you will get the best recommendation from our fellow DJI members who owns the DJI Mini 2 and are using a solar panel to do this process. Just a reminder that DJI do not recommend you to use a 3rd party chargers like powerbanks to charge your DJI Mini 2's intelligent flight battery. There is a possibility that these charger will work, however, since it's not tested by DJI we cannot guaranteed the reliability of the said charger. In addition, using 3rd party chargers like power banks might cause damage or harm on your DJI Mini 2 intelligent flight batteries and can void the warranty as well. Thank you.
Hi Stephen,
The original DJI two-way charging hub for the mini2 needs an input voltage of 5, 9 or 12 Vdc.
Output voltage to the battery in the hub is max 8.8 Vdc.
So where is the intelligent part of the mini2 battery ? Is it in the original charger or in the battery ?
I asked my mini2 battery if it can feel difference in loading voltage of the original dji charger or on a non original charger. Answer was: nope, i just like to feel the correct voltage on my contacts, i have no idea from wich apparatus i get my juice....
Mayby it it wise for DJI to sell a smaller charger than the original charger for the MINI2, as it is often used for travellers who need small chargers for their car or motorcycle etc.
I use my original DJI mini2 batt charger at home, feed by 5 Vdc on a usb power supply, does work great ofcourse, on travelling i use a smaller charger, as said battery does not feel the difference. 8.8 loading voltage = 8.8 loading voltage (as long as the amps are below max value)
So how intelligent is the battery ??
cheers
JJB |
