relaxosmo
Flight distance : 180604 ft
Hungary
Chanc3: wrong, very wrong.
Why are you talking about DOF? With such a tiny sensor, everything from 0.5m to infinity is in focus.
And IF something is out of focus, that doesn't look like pixelated, like op sayed, just soft.
Dragonfly:
it's NOT because of tiny sensor, and not because of your card.
I tell you the secret:
it's about video compression!
Yes, i hear you: "but i read it's 100mbps quality"
Yes, bitrate can be 100mbps, but this is only one parameter from 100 of video encoding.
I'm sure with such a tiny, cheap drone and without active cooling, the used encoding algorithm
is also light and not so cpu hungry, compared to encoding on PC at 100mbps with handbrake.
If you are familiar with x264 encoding, there are profiles for example: fast, slow, ultraslow, etc.
All are different in encoding speed, and quality of course.
Here we see a bad example for 100mbps encode: lot of macroblock when there is lot of details
on the picture and you move fast. (incidentally this is the case with Osmo Action too in 4k/60p mode)
What can you do? Test all video modes, maybe 2.7k/30p is better. And fly/rotate slower.
Or use another drone |
