JJB*
Flight distance : 12225059 ft
hallmark007 Posted at 5-20 05:21
Well you’re completely wrong, 2 options and you can do more than than just set Rth height, may I suggest you go back and RTFM, "there are two different settings for Rth “ thats fact…
If you lose Radio Control RTH or landing Hover can kick in it doesn't mean you have lost Qcysync which is Video downlink.
nah, there is only 1 option for the "RTH | Descend | Hover" setting, not 2, it is called the signal lost option. This option only to be found once in the FlyApp menu.
The other option wich relates to the RTH mode is the user RTH setting. (no need to read the manual for this)
Never heard of the RTFM, for me it is RTM ;-) , but you may use the F word.
Problem is to be found in the conversion of *txt file to * csv file, all data in the *txt so my drone is quite happy.
OcuSync handles and the up/down link for data (rc commands and parameters values xfer, and ofcourse the video data is done over this link.
Btw Dutch sheep uses ear protection plugs, part of the well being of animals because of low flying aircraft corridors, so they don`t get upset by mini2 humming.... ;-)
cheers
JJB
