DJI Gamora
Hi, sbuyuksayar. Thanks for reaching out! Please press the function button on the charging hub once to activate charging if charging does not begin automatically. In addition, when using the MAVIC Mini Two-Way Charging Hub (hereinafter referred to as "charging hub") to charge the Magic Mini Intelligent Flight Batteries, it is recommended to use a DJI 18W USB Charger or an FCC/CE-certified USB charger that supports Quick Charge protocol. |
