AlansDronePics
Flight distance : 814751 ft
Jersey
doglaboi Posted at 5-23 09:09
But didn't you approach the drone with your remote with you when you did the battery swap? Of course that would not be the same case the OP described wanting to know. He wants to stay put right where he is (home point), land the drone couple of miles away at his friend's house, have his friend change the battery there, and then try to fly back. If at that distance the remote can pair with the drone at startup that would be awesome.
Nice shots bytheway.....
Point taken, however, the communication between the drone and controller on restart was a viable one. By that i mean, the two were close enough to communicate and not out of range.
Just think, whether you are stood next to it or within range some miles away, the drone and controller will communicate just fine.
I know this also works if the phone or controller breaks communication and they have to be rebooted whilst the drone is in flight, communication becomes restablished. Yes, the drone will be returning to home by then, but still a long way off. |
