Northwood
Flight distance : 2148596 ft
Okay, so everything the others said applies... here's some suggestions. Learn how to use ND filters along with setting the exposure/frame rate accordingly. If you are using 4k-25, then add an ND filter (16 or 32 both will work well on sunny days) and set your exposure to manual, and to a value of 1/50. (this complies with the "180" rule, which gets you around having a fixed aperture camera). This creates motion blur which will help your image look more cinematic. Turn off auto white balance and set it around 58000 or so. Now your drone camera is in full manual video mode. The 180 rule has nothing to do with Panos... I think you may have misunderstood DAFly's post.
Another problem many have reported is that the video image is overly sharp... the ND smoothing will help with this somewhat, but there is no way to soften the image in the software. (even though we've begged DJI for such an option). There are plugins for some video editors which can reduce sharpness, you can google for those! I have found that using a CPL filter on the drone can remove some harshness from leaves on trees, but those filters can create issues with wide shots and lens flares. Okay for close up tree top stuff.
Hope any of this helps. Cheers.
