Montfrooij
Flight distance : 2560453 ft
Ranjan Posted at 5-25 06:49
Iphone timelapse will be much better than pocket timelapse, to add motion I suggest you buy osmo mobile gimbal OM-4 then use mimo app via iphone to shoot motionlapse that will give you better results, only downside would be no wider lens so for that you can buy add on lens for iphone. Creator combo is not much use for you as you can do same function with OM4 gimbal
Thanks for the reply!
You don't like the Pocket 2 for motion timelapses?
Funny since I sold my Osmo Mobile (used with an iPhone SE) because the motion timelapse did not work as hoped / expected.
Both image quality and the whole process.
I have started multiple threads about it in the past, but nothing was fixed.
The output was super super compressed with lots of artifacts and the motion was not consistently fluid (my suspicion is that a gimbal by default is not made to be very good at this, as it was made to move and correct movement) and with the heavy phone on top, combined with a weird balance because of the odd tripod mount placement it did not take much wind to make it move.
Also I noticed there was a lot of times the process simply aborted with unexplainable errors. (again, many posts about this, also with support, nothing fixed)
To this day I have yet to see a decent Osmo Mobile Motion timelapse on youtube (not from the 'paid' youtubers that make tutorials etc. but from a real user) that shows they fixed these issues.
Of course, they might have solved it, but I have yet to find proof of that.
The 2nd Reason why I am thinking about a Pocket 2 instead of an Osmo Mobile is because I don't like to have my phone doing something for quite a long time (not being able to use it in the meantime). This drastically reduces the available time that I can make motion timelapses (since I usually need my phone)
So I thought the P2 might be a good option.
(I could buy a second phone, but that does not make much sense to me)
The 3rd reason I did not look at the Osmo Mobile again is that editing and working with iPhone files is not really working for me.
Somehow my editor just does not like them and stops working when I add more than a couple.
Also moving the files conveniently to my PC is a pain in the you know where.
So unless some can really convince me the quality is 10x better, I will consider getting one again. |
