Hello,
So i have some code to execute a waypoint mission, the code runs and it seems to get loaded to the drone but nothing happens. Any help understanding what im doing wrong as well as how i can fix that would be greatly appreciated.
func waypointMission() -> DJIWaypointMission? {
/// Define a new object class for the waypoint mission let mission = DJIMutableWaypointMission() print("mission activated") mission.maxFlightSpeed = 15 // user can speed up flight by holding the stick up this is the limit of the added acceleration mission.autoFlightSpeed = 8 // the flight speed the drone will travel at mission.finishedAction = .goHome // when the mission is finished the drone will return home mission.headingMode = .auto mission.flightPathMode = .normal mission.rotateGimbalPitch = false /// Change this to True if you want the camera gimbal pitch to move between waypoints mission.exitMissionOnRCSignalLost = true mission.gotoFirstWaypointMode = .pointToPoint mission.repeatTimes = 0
/// Keep listening to the drone location included in latitude and longitude guard let droneLocationKey = DJIFlightControllerKey(param: DJIFlightControllerParamAircraftLocation) else { return nil } guard let droneLocationValue = DJISDKManager.keyManager()?.getValueFor(droneLocationKey) else { return nil } let droneLocation = droneLocationValue.value as! CLLocation let droneCoordinates = droneLocation.coordinate /// Check if the returned coordinate value is valid or not if !CLLocationCoordinate2DIsValid(droneCoordinates) { return nil } mission.pointOfInterest = droneCoordinates
let loc1 = CLLocationCoordinate2D(latitude: pointList[0].position.latitude, longitude: zeusPointList[0].position.longitude) let waypoint1 = DJIWaypoint(coordinate: loc1)
waypoint1.altitude = 2.0 /// The altitude which the drone flies to as the first point and should be of type float waypoint1.heading = 0 /// This is between [-180, 180] degrees, where the drone moves when reaching a waypoint. 0 means don't change the drone's heading waypoint1.actionRepeatTimes = 1 /// Repeat this mission just for one time waypoint1.actionTimeoutInSeconds = 60 // waypoint1.cornerRadiusInMeters = 5 waypoint1.turnMode = .clockwise /// When the drones changing its heading. It moves clockwise waypoint1.gimbalPitch = 0 /// This is between [-90, 0] degrees, if you want to change this value, then change rotateGimbalPitch to True. The drone gimbal will move by the value when the drone reaches its waypoint waypoint1.speed = 0.5 /// Note that this value does not make the drone move with speed 0.5 m/s because this is an error from the firmware and can't be fixed. However, we need to trigger it to be able to change the next one
let loc2 = CLLocationCoordinate2DMake(pointList[1].position.latitude, zeusPointList[1].position.longitude) let waypoint2 = DJIWaypoint(coordinate: loc2) waypoint2.altitude = 15.0 /// should be of type float waypoint2.heading = 0 waypoint2.actionRepeatTimes = 1 waypoint2.actionTimeoutInSeconds = 60 waypoint2.cornerRadiusInMeters = 5 waypoint2.turnMode = .clockwise waypoint2.gimbalPitch = 0 /// Chnage the velocity of the drone while moving to this waypoint waypoint2.speed = 0.5
mission.add(waypoint1) mission.add(waypoint2)
if let error = DJISDKManager.missionControl()?.waypointMissionOperator().load(mission) { print(error.localizedDescription) } DJISDKManager.missionControl()?.waypointMissionOperator().addListener(toUploadEvent: self, with: DispatchQueue.main){ error in print("upload") self.startMission((Any).self) }
print("running mission", mission) return DJIWaypointMission(mission: mission)
