AlansDronePics
Flight distance : 814751 ft
Guernsey
Option 1, because you have an older Samsung phone with a SD card storage. Swap drone SD for phone SD and over free wifi send content to Onedrive, Googledrive or similar.
Option 2, (depending on the kit you already own) use an adaptor to accept a USB card reader connection to the phone and use free wifi to online mass storage as above.
I imagined you might have more video than storage space on the phone, but using the USB connector, you can move files to the phone or SD storage on the phone.
Option 3 might be useful for other occasions as well. This uses a cheap, mini router. This way, you can plug the drone card into the router (my old mini router took the card directly). The router shown needed a card reader. This way, you can copy the drone card to your phone OR send content to online storage using the router as a hotspot. It is also possible, because the device is powered from a 5 volt supply, you could move the drone card content to an external hard drive which would be using another socket on the card reader/adaptor like the multiport adaptor with the red Samsung SD card. Where you can get this router.
