JJB*
Flight distance : 12225059 ft
DJI Stephen Posted at 6-3 18:47
Hello there Denndb. Good day and thank you for reaching out. Just a reminder that when flying above the water, the vision positioning function will turn off and only the GPS and barometer are used for positioning, if affected by the accuracy range, and an accident might happen. In addition, I will also post a DJI Forum thread on How to Fly Safely Over Water. Thank you and fly safe always.
https://forum.dji.com/thread-181878-1-1.html
Hi Stephen,
Your link to "How to Fly Safely Over Water" is an old video DJI GO4, in wich you could disable the bottom sensor.
MINI2 uses FlyApp, you cannot disable the VPS bottom sensor!
Your text is confusing beacuse you state that "the vision positioning will turn off".
Vision does not turn off, if out of range and or signals are not good enough, the vision system does not function but will function again if enough signals are received.
If the vision position is not function, the bottom sensor may function oke, so height is controlled by barometric sensor assisted by the bottom sensor (VPS height).
Please explain "...if affected by the accurancy range..." Range from vision sensors or bottom sensor?
GPS is used for positiong, barometer for controlling height (not positioning).
Wish we had the possibility in the FlyApp to enable/disable the downward sensor AND enable/disable Landing Protection !!
cheers
JJB |
