patiam
Flight distance : 1118740 ft
This is a known intermittent problem with this unit. It seems to occur if the D-RTK 2 still has previous base location coordinates in its memory somewhere (has not cleared them out automatically as it should) and that location is farther away than the error threshold. There may be other causes as well.
Getting the unit to accept the true known coordinates for your benchmark may require putting it in autonomous mode for a bit and then going back to trying to enter your coordinates again, as well as cycling the power.
There should be a way to see or at least clear any coordinates currently in memory, but there are many things about this kit that "should be", such as separating out (and remembering) the rod height/APC offset from the benchmark Z coordinate, storing NTRIP setups, allowing one to see the password entered for an NTRIP caster, reading the mountpoint list from the NTRIP caster, etc. |
