Tosis
Confirmed issue with iPadOS 14.6 and controller USB type-A socket
Confirmed your experience with my Mavic Pro and iPad running iPadOS 14.6.
Specifics:
iPad 12.9” 4th generation cellular model, iPad OS v14.6, DJI Go 4 v4.3.42
GL200A controller, drone, and battery all running on latest firmware with latest available geozone data loaded
When I connect a USB 3.1 certified type-A to type-C cable between the controller and iPad, the tablet briefly indicates that it is charging, then changes state to not charging. There is no indication that the two devices communicate.
That said, if I use the micro-USB to USB-C cable provided with the controller (all of 2” inches long, <7cm) then the two happily connect and both DJI Go 4 and AirMap happily behave as I’d expect them to under normal circumstances.
My inexpert thoughts - the tablet sees the controller as a power source and not a host device. I’ll leave it to DJI to investigate and take appropriate action. In the interim I’m either reverrting to using a phone or purchasing a micro-USB to type-A adapter dongle.
@DJI staff - it’s been 5 months since the last update to DJI Go 4 and a month since Red Dirt posted this initially. Referring to the Mavic Pro, it’s also been nearly 2 years, at a guess, since the last firmware updates for controller, drone, or batteries were last released. Do we expect to any effort to resolve this issue with iPad OS 14.6+ and the controller USB-A socket? |
