Hello I have a question to ask : the power connectors XT30 and XT60 deliver a variable voltage from 2 to 26V . Dafault to have been set on 22.2 V . As it sets the output for example of 13 V ? Thank you, and have a nice day
There are three XT30 ports and one XT60 port reserved on the center frame.
The specifications of these four reserved ports are as shown below:
Output Voltage Range : 20 ~ 26.1 V
Max. Persistent Output Current : 10 A
Thank you for your kind reply . But tensions are adjustable independent for each port ? There are trimmer to adjust or jumpers ? I need to connect loads that work with voltage of 13V
I read the specifications published by you this note :
"The features of output electric current andvoltage on XT30 port and XT60 port?
Each XT60 port and XT30port contain the following features:
Output voltage range
2-26.1V(the output voltage stays at 22.2V instead of in a range value)
Max constant output current 10A "
Note: the total current of all the reserved XT60 ports and XT30 ports cannot exceed10A.
