JJB*
Flight distance : 12225059 ft
sensiblesnake Posted at 6-23 05:11
OK I figured out how to get the logs on newer macOS and I identified the right log, but I can't use airdata because they never send me a confirmation e-mail, phantomhelp.com log viewer only produces garbage. I can watch my flight in the DJI app though. At 2:25 I see "weak signal..st antennas", at 2:28 I see "Aircraft landing automatically. Exited QuickShots." Then I see "weak signal..st atennas" and "Aircraft landing automatically. Exited QuickShots." Alternating back and forth and sometimes both on the screen at the same time. Then "In flight", then all messages disappear for about 10 seconds then "weak signal..st atennas" and "Aircraft landing automatically. Exited QuickShots." again then at 2:58 "Aircraft sig..I interference" with "Aircraft landing automatically. Exited QuickShots" At some point here I was frantically trying to cancel landing and instead issue the return home command. I took off a again in another direction and basically the whole thing repeated all over again. How do I tell what it was actually doing whether it was RTH or landing and if landing why it was landing and not RTH?
Hi,
Had a look at your flight too.
I do not have a explanation for 16 times an "Aircraft landing automatically" message. (but it did not land....just check the descent value in the app next time)
After RTH is activated ; check the distance in the app, value should decrease as it is flying towards home (after climbing first (if flown < rth height setting) and aligning to home)
More weird is the 12 times "Exited QuickShots", as no Quickshot mode was flown in the log.
At the end in the flight this message "Aircraft may be in violation of local laws and regulations | Check and make sure you have obtained proper authorization to fly in this airspace"
Mayby something to do with the landing message, if drone is flying in a forbidden zone (or think it is there....) it will do an autolanding.
But your flight was close but not in the airspace zones, see the map.
I would suggest to fly in another place, further away from Sofia airspace, see if this kind of messages are seen again when flying.
cheers
JJB
