JJB*
Flight distance : 12445630 ft
Hi,
Yes, so blades are oke....
Had a look at your flightlog, it is amazing !
Heading really stable but your MINI2 made left circle moves, see the move line in my chart.
Chart with numbers, see the HDG and MOVE column.
GPS signals good indicating, so problem imo a compass error.
But never seen this before, "normal' for a compass error is flying much bigger circles or ovals....
Compass or Yaw error will sometimes result in a "toilet bowl" move, because correcting software inputs are directed to the wrong blades as the 'computer' thinks that drone is at a other heading than the actual heading.
So my advice, again a IMU calibration and a compass one.
Fly again, if persists go for DJI support to help you out (warranty) [ fly close to home, free area so you can land asap if uncontrollable ]
PS1 do you know wich heading your drone was facing at startup/manual takeoff ??
PS2 Always check the heading in the map view in the app before takeoff, compare with the actual heading! if not equal; don`t fly.
cheers
JJB
