banesbane2991
I am having an issue with range and I believe it is that the air unit is not sending any signal through the antenna. I crashed and was able to keep flying no problem, about 2 minutes later, I was roughly ~25M away from myself and lost all video signal suddenly. The unit powers on normally, I can update the firmware and I have clear picture in the goggles up to ~2M away from the air unit. After that it begins to degrade extremely quickly and loses connection at about 6M.
Let me walk you through what I've done:
Replaced MMCX connectors interally
Replaced antennas
Checked cables running to FC with continuity checker
Most notably: Unplugged antennas while the unit was on with no change in transmission range. This leads me to believe that the signal isn't making it to the antennas at all.
I have ordered a replacement unit, but I am curious if anybody is aware of a way to repair the one I have? Could it be the Ribbon cable? The upper board that holds the MMCX connectors?
